October 2, 2016, 10:07 |
patch problem
Rep Power: 10 |
Hi all,
I need a little help, please. I'm trying to build a mesh with snappyHexMesh, it consist basically in a series of pipes, some of which are concentrics. Following your advice I first draw a cad model and add two bidimensional disks for the inlet and outlet patches inside the 3d model. Then I export three stl files, inlet outlet and main body, and after converting them from binary to ascii I merge them in a single file. I can correctly import the stl with patches inside in discretizer and build the mesh, but I see in parafoam that only outlet and main body are listed along with internal mesh, which was not inside my stl file. I can't understand why inlet is missing and outlet is available. Thanks for any help. |
discretizer, snappy hex mesh, stl |
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 37 | November 29, 2024 11:15 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 13:23 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
