[snappyHexMesh] Parallel processing SnappyHexMesh
Old   September 21, 2016, 22:55
Default Parallel processing SnappyHexMesh
jim
mullet904 is on a distinguished road
Trying to solve a case with simpleFoam in parallel.
I create the mesh using SHM in parallel, edit polymesh/boundary removing the patches from blockMesh, then solve with simpleFoam without issue.
However, if I decomposePar after mesh generation so I may run simpleFoam in parallel, decomposePar exits with error.....
Create mesh
Calculating distribution of cells
Selecting decompositionMethod simple
Finished decomposition in 0.35 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
--> FOAM FATAL ERROR:
Cell 0contains face labels out of range: 6(0 1 2 -1 -1 -1) Max face index = 384999
From function Foam:olyMesh:olyMesh(const Foam::IOobject&, const Foam::Xfer<Foam::Field<Foam::Vector<double> > >&, const Foam::Xfer<Foam::List<Foam::face> >&, const Foam::Xfer<Foam::List<Foam::cell> >&, bool)
in file meshes/polyMesh/polyMesh.C at line 629.
FOAM aborting
if I checkMesh at this point, I get error
Checking topology...
****Problem with boundary patch 0 named inlet of type wall. The patch should start on face no 1489753 and the patch specifies 1504753.
Possibly consecutive patches have this same problem. Suppressing future warnings.
***Boundary definition is in error.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
inlet 3195 4013 ok (non-closed singly connected)
outlet 3981 4655 ok (non-closed singly connected)
pipe 53736 68594 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.1 -0.1 -0.1) (0.1 0.1 0.1)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-2.7816346e-16 -5.7216192e-17 2.1630651e-15) OK.
Max cell openness = 3.9992999e-16 OK.
Max aspect ratio = 10.604633 OK.
Minimum face area = 2.7188777e-09. Maximum face area = 1.6741e-05. Face area magnitudes OK.
Min volume = 4.2935824e-13. Max volume = 6.5925713e-08. Total volume = 0.0079973385. Cell volumes OK.
Mesh non-orthogonality Max: 64.867432 average: 12.822348
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 3.0829412 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
If think it has something to do with how I am editing out the blockMesh patches in /polymesh/boundary file but I just am not able to figure it out.
Any help would be appreciated.
mullet904 is offline   Reply With Quote
Old   September 22, 2016, 21:55
Antimony is on a distinguished road
I don't quite understand. You have already decomposed the case and then run snappyHexMesh. Any particular reason to decompose the case again??
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   September 23, 2016, 17:56
jim
My understanding is that if I decomposePar to run snappyHexMesh in parallel, I must reconstructParMesh to make a proper mesh representing my model geometry when SHM completes. At that point, the polymesh/boundary file is rewritten reflecting the patches SMH creates. I decomposePar again to prepare the case for the simpleFoam run in parallel.
If I do not reconstructParMesh and proceed with simpleFoam, my patches from SHM are not recognised because the polymesh/boundary only knows about the results of blockMesh.
I'll try running SHM in serial, see if I can make headway since the solution takes much longer and would benefit from parallelization more than SHM though I'm not optimistic it will succeed....
Thanks.
Old   September 24, 2016, 09:10
There are a couple of approaches to your problem, at least from my experience:
1. Run snappyHexMesh in serial and then run decomposePar. This is typically the workflow I use, but it might not be a good idea if your mesh is going to be large and will take a lot of time to generate.
2. Run decomposePar and then use snappyHexMesh in parallel. At the end of your snappyHexMesh, the polyMesh/boundary file on each of the processors should be updated with the patches introduced by snappyHexMesh. For the BC in say the 0 folder, if I use this route, I will simply put in all patches for all the variables. For the processor patches, I simply put (if my memory serves me right):
"proc*.*"
type processor;
As I typically run renumberMesh after snappy (strongly recommended by the way), it will expand the proc entries as needed for each of the processor directories.
I do not touch the polyMesh/boundary files unless I want to examine something or manually remove patches with zero number of faces. I don't change the numbering of the faces or the startFace or any of those details. Also, I usually run snappy with the -overwrite flag so that I don't have any confusion of which time folder I need to use as my starting point.
Hope this helps at least a little bit.
Cheers,
Antimony
Last edited by Antimony; September 24, 2016 at 22:36. Reason: Changed from proc*.* to "proc*.*"
Old   September 24, 2016, 17:22
jim
Option 1 SMH exits after running serially without error.
a. decomposePar with removal of BlockMesh patched from polymesh/boundary...decomposePar exits with original error.
b. decomposePar without removing BlockMesh patches from polymesh/boundary...decomposePar exits with error .
Create time
Decomposing mesh region0
Create mesh
Finished decomposition in 0.23 s
Reading hexRef8 data : cellLevel
Reading hexRef8 data : pointLevel
Reading hexRef8 data : level0Edge
Reading hexRef8 data : refinementHistory
Processor 0
Number of cells = 72533
Number of faces shared with processor 1 = 4388
Number of processor patches = 1
Number of processor faces = 4388
Number of boundary faces = 13222
Processor 1
Number of faces shared with processor 0 = 4388
Number of faces shared with processor 2 = 3618
Number of processor patches = 2
Number of processor faces = 8006
Number of boundary faces = 25490
Processor 2
Number of faces shared with processor 1 = 3618
Number of faces shared with processor 3 = 5040
Number of processor faces = 8658
Number of boundary faces = 26493
Processor 3
Number of cells = 72532
Number of faces shared with processor 2 = 5040
Number of processor faces = 5040
Number of boundary faces = 13091
Number of processor faces = 13046
Max number of cells = 72533 (0.00034467189% above average 72532.75)
Max number of processor patches = 2 (33.333333% above average 1.5)
Max number of faces between processors = 8658 (32.730339% above average 6523)
Time = 0
--> FOAM FATAL IO ERROR:
Cannot find patchField entry for maxY
file: /home/jim/A_OpenFoam/pipe/0/epsilon.boundaryField from line 26 to line 36.
From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam:imensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
in file /home/openfoam/OpenFOAM/OpenFOAM-4.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191.
FOAM exiting
==============> maxY is a patch from blockMesh, I originally edited polymesh\boundary to remove the blockMesh patches to avoid this error.....however, I introduced the above error.....
Thanks
Old   September 24, 2016, 22:38
I don't quite understand still why you manually edit the entries in polyMesh/boundary for the entries obtained from blockMesh.
Can you upload your blockMeshDict, snappyHexMeshDict and the STL files you are using to create the mesh for this case?
Cheers,
Antimony
Old   September 25, 2016, 14:30
jim
Attached are the files I can send with .txt extention....the pipe stl is 7.8MB thus to large to send.......
Problem in parallel processing [Process affinity not being set] Roh FLUENT 4 October 26, 2023 04:42
Parallel processing of OpenFOAM cases on multicore processor??? g.akbari OpenFOAM Running, Solving & CFD 31 November 1, 2017 10:25
wrong zero boundary dir in parallel after snappyHexMesh HagenC OpenFOAM Pre-Processing 2 March 13, 2017 05:47
DEFINE_ZONE_MOTION in 3D parallel processing LoUcAsss Fluent UDF and Scheme Programming 4 June 24, 2014 17:00
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
