[snappyHexMesh] Obtaining two regions from background mesh
Old   September 19, 2016, 03:39
Default Obtaining two regions from background mesh
cfdsolver1 is on a distinguished road
Hello everyone. I am working on a complex geometry so I need to use STL file to generate mesh. What I am doing is, I create a bounding box using blockMesh. Then, I run snappyHexMesh to obtain background mesh and this creates new boundary for me. Using this boundary, I need to split STL file as solid region and the rest of the mesh as fluid region. I run setSet to create zone from boundary:
setSet
faceSet f0 new patchToFace myWall
cellSet c0 new faceToCell f0 any
cellZoneSet c0 new setToCellZone c0
Using this cell zone, I want to split my mesh into 2 regions. If I run
splitMeshRegions -cellZones
command, I get thousands of domains (because of porous structure). If I use cellZonesOnly option of splitMeshRegions, I get an error:
For the cellZonesOnly option all cells have to be in a cellZone.
I just need to have 2 regions. The cells in the regions are not required to be connected to each other. One of other post here suggests using topoSet but I am lost while using it. Can you help me to split my domain0 into two regions? This is the domain I am working on:
Thank you so much.
cfdsolver1 is offline   Reply With Quote
Old   September 21, 2016, 17:30
Roberto
RobertoCirolini is on a distinguished road
If I understood what you want to do, I would suggest you play around with sHM. Therefore you can split your regions. I do believe topoSet would put you into trouble and make you waste a lot of time.
I think this thread is about what you want.
http://www.cfd-online.com/Forums/ope...ous-media.html
Regards,
Roberto
RobertoCirolini is offline   Reply With Quote
Old   September 21, 2016, 20:38
Dear Roberto,
Thank you so much for your reply. I am able to obtain a mesh using sHM like the post you posted but my problem is, If I use sHM I get the solid region as a boundary. However, I want to name my STL file as cellZone; not as boundary. Is this possible with sHM?
Old   September 23, 2016, 12:18
Antimony is on a distinguished road
Have you tried the option "cellZoneInside inside;" and the associated ones as stated in slide 31 here: http://openfoamwiki.net/images/f/f0/...SlidesOFW7.pdf
Does it do what you want?
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   September 26, 2016, 13:53
Hello again, thanks for the tips. I guess I was able to split mesh into two regions but I am not sure if I did it correctly or not. I used
setSet
and starting from boundary, I created a cell zone and inverted it and obtained second zone. Then I applied
splitMeshRegions -cellZonesOnly
and created two zones and I was able to run chtMultiRegionSimpleFoam but I have a problem.
If I run chtMultiRegionSolver, the h equation at fluid region decreases and goes to minus values, which is of course wrong. If I solve solid region only, everything is okay. If I run only fluid region using chtMultiRegionSolver, it doesn't work again. So, what might be problem? Can you help me? If I use
checkMesh -region fluid
I think everything looks okay. How can I ensure if the problem is boundary conditions or model, or mesh?
setset, snappyhexmesh, toposet
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
pimpleDyMfoam , AMI -- The mesh has multiple regions not connected by any face coolcrasher OpenFOAM Running, Solving & CFD 3 May 16, 2019 06:58
[Gmsh] gmshToFoam - Hybrid mesh conversion creates 2 regions bhanu2204 OpenFOAM Meshing & Mesh Conversion 5 February 18, 2018 08:04
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
