[Other] error: faces are incorrectly oriented
Old   September 2, 2016, 11:32
Default error: faces are incorrectly oriented
Sergio
sergiopb91 is on a distinguished road
Hi all.
I made a Venturi tube jointed with a small cylinder but when ran checkMesh got the following error:
Overall domain bounding box (0 -0.016 -0.016) (0.182 0.016 0.016)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (7.20866e-20 -2.52969e-15 -6.29467e-15) OK.
Max cell openness = 3.75848e-16 OK.
Max aspect ratio = 189.126 OK.
Minimum face area = 4.86213e-12. Maximum face area = 1.39607e-06. Face area magnitudes OK.
Min volume = 1.55748e-14. Max volume = 7.9738e-10. Total volume = 0.000108002. Cell volumes OK.
Mesh non-orthogonality Max: 88.6327 average: 22.3043
*Number of severely non-orthogonal (> 70 degrees) faces: 19911.
Non-orthogonality check OK.
<<Writing 19911 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 10 faces are incorrectly oriented.
<<Writing 10 faces with incorrect orientation to set wrongOrientedFaces
***Max skewness = 4.47115, 2 highly skew faces detected which may impair the quality of the results
<<Writing 2 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 2 mesh checks.
I read that this error occurs due to an incorrect order in points or blocks so I changed the order and didn't work. This is my mesh:
vertices
(0 0 16) // 0
(0 16 0) // 1
(0 0 -16) // 2
(0 -16 0) // 3
(40 0 16) // 4
(40 16 0) // 5
(40 0 -16) // 6
(40 -16 0) // 7
(60.840712 0 8) // 8
(60.840712 8 0) // 9
(60.840712 0 -8) // 10
(60.840712 -8 0) // 11
(76.840712 0 8) // 12
(76.840712 8 0) // 13
(76.840712 0 -8) // 14
(76.840712 -8 0) // 15
(141.995484 0 16) // 16
(141.995484 16 0) // 17
(141.995484 0 -16) // 18
(141.995484 -16 0) // 19
(182 0 16) // 20
(182 16 0) // 21
(182 0 -16) // 22
(182 -16 0) // 23
(65.840712 8 0) // 24
(68.840712 7.416198487 3) // 25
(71.840712 8 0) // 26
(68.840712 7.416198487 -3) // 27
(65.840712 12 0) // 28
(68.840712 12 3) // 29
(71.840712 12 0) // 30
(68.840712 12 -3) // 31
blocks
hex (0 3 2 1 4 7 6 5) (60 40 40) simpleGrading (1 1 1)
hex (4 7 6 5 8 11 10 9) (60 40 40) simpleGrading (1 1 1)
hex (8 11 10 9 12 15 14 13) (60 40 40) simpleGrading (1 1 1)
hex (12 15 14 13 16 19 18 17) (60 40 40) simpleGrading (1 1 1)
hex (16 19 18 17 20 23 22 21) (60 40 40) simpleGrading (1 1 1)
hex (28 31 30 29 24 27 26 25) (60 40 40) simpleGrading (1 1 1)
edges
arc 0 1 (0 11.3137085 11.3137085)
arc 1 2 (0 11.3137085 -11.3137085)
arc 2 3 (0 -11.3137085 -11.3137085)
arc 3 0 (0 -11.3137085 11.3137085)
arc 4 5 (40 11.3137085 11.3137085)
arc 5 6 (40 11.3137085 -11.3137085)
arc 6 7 (40 -11.3137085 -11.3137085)
arc 7 4 (40 -11.3137085 11.3137085)
arc 8 9 (60.840712 5.656854 5.656854)
arc 9 10 (60.840712 5.656854 -5.656854)
arc 10 11 (60.840712 -5.656854 -5.656854)
arc 11 8 (60.840712 -5.656854 5.656854)
arc 12 13 (76.840712 5.656854 5.656854)
arc 13 14 (76.840712 5.656854 -5.656854)
arc 14 15 (76.840712 -5.656854 -5.656854)
arc 15 12 (76.840712 -5.656854 5.656854)
arc 16 17 (141.995484 11.3137085 11.3137085)
arc 17 18 (141.995484 11.3137085 -11.3137085)
arc 18 19 (141.995484 -11.3137085 -11.3137085)
arc 19 16 (141.995484 -11.3137085 11.3137085)
arc 20 21 (182 11.3137085 11.3137085)
arc 21 22 (182 11.3137085 -11.3137085)
arc 22 23 (182 -11.3137085 -11.3137085)
arc 23 20 (182 -11.3137085 11.3137085)
arc 24 25 (66.719392 8 2.121320)
arc 25 26 (70.962032 8 2.121320)
arc 26 27 (70.962032 8 -2.121320)
arc 27 24 (66.719392 8 -2.121320)
arc 28 29 (66.719392 12 2.121320)
arc 29 30 (70.962032 12 2.121320)
arc 30 31 (70.962032 12 -2.121320)
arc 31 28 (66.719392 12 -2.121320)
boundary
inlet
type patch;
faces
(0 3 2 1)
outlet
type patch;
faces
(20 23 22 21)
rightup
type wall;
faces
(0 1 5 4) (4 5 9 8) (12 13 17 16) (16 17 21 20)
leftup
type wall;
faces
(1 2 6 5) (5 6 10 9) (13 14 18 17) (17 18 22 21)
rightdown
type wall;
faces
(0 3 7 4) (4 7 11 8) (8 11 15 12) (12 15 19 16) (16 19 23 20)
leftdown
type wall;
faces
(2 3 7 6) (6 7 11 10) (10 11 15 14) (14 15 19 18) (18 19 23 22)
atmosfera
type patch;
faces
(28 31 30 29)
smallcylinder
type wall;
faces
(24 25 29 28) (25 26 30 29) (26 27 31 30) (27 24 28 31)
masterPatch
type patch;
faces
(24 27 26 25)
slavePatch
type wall;
faces
(8 9 13 12) (9 10 14 13)
mergePatchPairs
(masterPatch slavePatch)
Can someone tell me where is the error?
Thanks in advantage.
sergiopb91 is offline   Reply With Quote
Old   September 9, 2016, 11:36
Sergio
Hi all.
I could run my case, changed the way of doing the cylinders and run correctly.
Thanks.
[Commercial meshers] non-orthogonality errors, incorrectly oriented faces cfdmarkus OpenFOAM Meshing & Mesh Conversion 15 June 13, 2024 13:02
Faces incorrectly oriented DURING the simulation Giuseppe23 OpenFOAM 0 March 9, 2015 14:14
[blockMesh] Problem with "faces are incorrectly oriented" The_Architect OpenFOAM Meshing & Mesh Conversion 2 January 31, 2013 06:50
How to avoid the generations of incorrectly oriented faces when morphing mesh fumiya OpenFOAM 0 October 22, 2012 00:16
Wrong oriented faces due to opposite face bends? Arnoldinho OpenFOAM 5 August 16, 2012 06:00
