[blockMesh] Parametric Multigrading
Old   August 26, 2016, 13:56
Default Parametric Multigrading
Mauricio Aguilar
MauricioAguilar is on a distinguished road
Hello foamers,
I'm using an extra file (parameters) to source all my variables into blockMeshDict and topoSetDict so I can easily adjust my geometry.
I have just finished including the multigrading section in BlockMeshDict and I'm getting supper weird results when including variables from "parameters"...if I define all multigrading parameters this way I even get a seg-fault. Using some hardcoded values allows blockMesh to solve but it does so with weird values.
Is there something similar to Printf with which I can print my variables after they were parsed?
I'm looking for a way to debug my code.
I have included my blockMeshDict and parameters file in case anyone wants to give it a try.
In blockMeshDict lines [42-47] i've hardcoded the values that should come from the calculated parameters established in parameters lines [117-123]. I've commented out the solution I would like to employ.
blockMeshDict.txt
parameters.txt
Any help is greatly appreciated.
kind regards,
Mauricio
MauricioAguilar is offline   Reply With Quote
Old   August 29, 2016, 23:38
Antimony is on a distinguished road
AFAIK, it isn't possible to output anything from blockMeshDict. This is probably because the dictionary is just that, a dictionary, and so OF is very clear in the type of information it needs in a dictionary under each of the headings.
In blockMesh you can probably add "Info << " to output what you want, but at the moment I do not know how you will be able to access the particular point/value you are looking for.
Hope this clarifies.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   August 31, 2016, 07:22
Mauricio Aguilar
Hi Antimony,
I supposed it wouldn't be possible. I'll try "Info <<" and will post any updates.
Thanks.
regards.
blockmesh, debug, multigrading, parameterization, printf
Parametric study by Ansys Workbench Sahar FaPerhu ANSYS 17 August 23, 2017 04:29
Problem with Parametric Study Picopico CFX 1 March 7, 2017 18:56
[ICEM] Parametric O-grid and Parametric Split Henry Arrigo ANSYS Meshing & Geometry 3 October 20, 2014 06:32
parametric study with design modeler and icepak aminem ANSYS 3 May 21, 2014 06:11
Comsol (4.3): convert parametric surface into block? sgalaz COMSOL 0 November 9, 2012 10:20
