[snappyHexMesh] Rhino surface problem in SnappyHexMesh
Old   August 10, 2016, 12:22
Default Rhino surface problem in SnappyHexMesh
Diana Hurtado B.
dshurtad is on a distinguished road
Hi everybody!
I'm trying to run a resistance simulation on OpenFOAM 3.0x using my own Hull generated on Rhinoceros. I followed the tutorial to export it to .STL format, but at the time to run snappyHexMesh I have this problem:
Scaling iteration 6
Moving mesh using displacement scaling : min:0 max:1
Checking faces in error :
non-orthogonality > 70 degrees : 856
faces with face pyramid volume < 1e-13 : 0
faces with face-decomposition tet quality < 1e-30 : 0
faces with concavity > 80 degrees : 0
faces with skewness > 4 (internal) or 20 (boundary) : 0
faces with interpolation weights (0..1) < 0.05 : 0
faces with volume ratio of neighbour cells < 0.01 : 0
faces with face twist < 0.05 : 0
faces on cells with determinant < 0.001 : 0
Successfully moved mesh
Patch points smoothed in = 14.31 s
Morph iteration 0
Calculating patchDisplacement as distance to nearest surface point ...
--> FOAM Warning :
From function autoSnapDriver::calcNearestSurface(..)
in file autoHexMesh/autoHexMeshDriver/autoSnapDriver.C at line 1759
For point:125 coordinate1.44804 -0.0688446 0.0565973) did not find any surface within:0.0104167 metre.
--> FOAM Warning :
For point:132 coordinate1 -0.0789813 0.0270923) did not find any surface within:0.0104167 metre.
I have tried a lot of ideas and don't know how to solve it.
Any idea?
This is the link of Hull Geometry: https://www.dropbox.com/s/gh6kr41fpn...nL.stl.gz?dl=0
Diana
dshurtad is offline   Reply With Quote
Old   August 12, 2016, 16:45
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear Diana,
this STL is not "mesh-able".
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh generates not planar surface krzychu111 OpenFOAM Meshing & Mesh Conversion 2 April 23, 2020 17:38
[snappyHexMesh] SnappyHexMesh - surface is not removed vmb OpenFOAM Meshing & Mesh Conversion 0 March 5, 2019 09:24
Problem with surface monitor position jf90cl FLUENT 0 April 28, 2016 12:41
[snappyHexMesh] Problem: after snappyHexMesh, the cells size are not the same kanes OpenFOAM Meshing & Mesh Conversion 0 January 25, 2016 09:06
[snappyHexMesh] bumpy on the surface of 3D wing in addlayer step with snappyHexMesh Kim sung hwan OpenFOAM Meshing & Mesh Conversion 2 April 21, 2015 04:51
