[snappyHexMesh] Multi region meshing with SHM creates extra regions |
August 8, 2016, 09:54 |
Rep Power: 10 |
Dear Foamers!
I'm trying to mesh a heat exchanger with SHM and whenever i try to rifne the mesh I get extra regions named domain0 ,domain1 and so on. I figured it out that the number of these extra regions depends on the refinement level. The STL I use is imported from Inventor I gladly welcome any tip/solution idea about this issue. Your sincerly David |
chtmultiregion, domain, shm |
Part based meshing VS Region based meshing | Bharatt | STAR-CCM+ | 6 | February 21, 2018 08:43 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 06:09 |
[snappyHexMesh] Multi Region Meshing | bruce | OpenFOAM Meshing & Mesh Conversion | 12 | July 31, 2013 11:09 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
