[snappyHexMesh] combining AMI and 6dof rigid bidy motion
Old   July 25, 2016, 10:24
Default combining AMI and 6dof rigid bidy motion
mo_na's Avatar
Mona
mo_na is on a distinguished road
Hi everyone,
is there a way to combine sixDoFRigidBodyMotion solver with an AMI?
I am trying to simulate a floating object in pitch motion which is close to another not moving rigid object. Around the floating object I defined a cylindrical part that should rotate in the main mesh. ( http://www.cfd-online.com/Forums/ope...ixed-body.html )
Instead of specifying a frequency omega with which the inner part rotates I would like it to rotate the same angle as the floating body. And I also don't want to define the innerDistance and outerDistance around the object. Then I would have interference problems with the other object.
Cheers,
Mona
mo_na is offline   Reply With Quote
[Tutorials] Flow induced rotation with AMI and 6DOF Tobi OpenFOAM Community Contributions 12 December 30, 2023 04:27
