[snappyHexMesh] where is mesh file
Old   July 16, 2016, 09:41
Default where is mesh file
mike6427 is on a distinguished road
Hello guys,
I'm very new to openFoam. Maybe my question is trivial but I searched the forum without success. I generated a mesh with Discretizer and snappyHexMesh. Following the instructions in the discretizer's screencast I succesfully import an stl file and after running snappyHexMesh everything goes ok and I can see the resulting mesh with paraFoam. What I can't figure out is where the mesh is located and what is the mesh file name and format. Opening the directories created by the process with paraview I can't find a single file that show me same mesh that I can see with the paraFoam command.
Thanks in advance
mike6427 is offline   Reply With Quote
Old   July 16, 2016, 10:00
Antimony is on a distinguished road
Your mesh is not one file. It is a bunch of files: points, faces, neighbour, owner etc. etc. Typically you can find them all in the constant/polyMesh folder. Or if not under constant, then in one of the time directories (depending on how you ran snappyHexMesh).
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   July 16, 2016, 16:53
Thank you Antimony,
the files are in polyMesh directory!
Cheers
discretizer, snappyhexmesh
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
