[Other] Meshing question for a conjugate heat transfer problem |
July 5, 2016, 23:21 |
anonymous
Dear FOAMers
I am conducting a simulation of conjugate heat transfer (CHT) problem in which the fluid flows in a heated circular tube. The solver ChtMultiRegionSimpleFoam is used. I am planning to add uniform volumetric heat source inside the solid domain (tube wall) using the fvOptions utility. At the solid-fluid interface the compressible::turbulentTemperature CoupledBaffleMixed is used. In the fluid domain, the mesh is refined at the solid-fluid interface since the flow is turbulent and I want the boundary layer to be solved using Low-Re turbulence models. My doubts are: 1 Whether the mesh in the solid domain needs to be refined in the radial direction as well or a uniform spaced mesh is OK? 2 If a nonuniform mesh in the solid domain has to be used, does it have to be adjusted under different heat source conditions? Thank you! |
conjugate heat transfer, mesh |
Conjugate Heat Transfer Analysis Problem | redwanamit034 | FLUENT | 1 | June 17, 2015 00:39 |
Issues with creating "regions" for conjugate heat transfer problem!! | vabishek | OpenFOAM Pre-Processing | 6 | April 23, 2015 17:23 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Conjugate heat transfer problem with porous media | piko | Siemens | 1 | April 17, 2009 16:41 |
conjugate heat transfer problem | Andreas | FLUENT | 2 | February 6, 2002 04:15 |
