[Salome] Converting from unv format shows error
Old   July 5, 2016, 15:26
Unhappy Converting from unv format shows error
Pratheesh Russell
pratheeshrussell is on a distinguished road
I am new to linux as well as openfoam. using lubuntu 16.04 and openfoam 3.0.1. created a simple pipe in freecad. created inlet,outlet,wall groups and meshed in salome and exported the mesh in unv format. Now when i type the command ideasUnvToFoam i get this error
Sorting boundary faces according to group (patch)
0: inlet is #0 Foam::error:: printStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? at ??:?
#4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#5 ? at ??:?
Segmentation fault (core dumped)
how do I fix this
I followed this tutorial https://www.youtube.com/watch?v=1zQbU-E4k1U
pratheeshrussell is offline   Reply With Quote
ideasunvtofoam, mesh
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
