June 29, 2016, 10:41 |
layer addition
Almond Wong
Rep Power: 10 |
i trying to do a mesh around a domain of a city. this can be easily done with snappy function. But in order to make the mesh better, I though of adding layers. At the moment, the layers are weird in the sense that it stop at those sharp edges. Is there anyway to avoid this? Attached is a picture of the different layer effect. The one on the right is what i am aiming for. Any idea how to get to that? |
June 29, 2016, 15:15 |
Kaufman
Rep Power: 13 |
Increasing the featureAngle entry (which located at sub-dictionary of controls for layer addition) to 130 may work. |
June 29, 2016, 15:21 |
Almond Wong
Rep Power: 10 |
hi, Thank you for the reply. But it doesnt solve it. I even tried with 180.
June 29, 2016, 16:04 |
Kaufman
Rep Power: 13 |
It will be easier to identify the problem, if you can upload your test case. |
June 29, 2016, 16:09 |
Almond Wong
Rep Power: 10 |
Hi, this is the same tutorial as in the picture, i have also attached the file.
layer |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 09:26 |
[snappyHexMesh] SHM Layer Addition Phase | dickcruz | OpenFOAM Meshing & Mesh Conversion | 4 | November 1, 2018 08:05 |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 06:53 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 08:48 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 14:20 |
