[snappyHexMesh] Remove snappyHexMesh bad cells (subSetMesh)
Old   June 24, 2016, 07:17
Question Remove snappyHexMesh bad cells (subSetMesh)
Max Vorstadt
jet_engine is on a distinguished road
Hi! I'm using snappyHexMesh to mesh around a plate and a cylinder and apparently I am having some problems with the addLayers step. Layers are created, but after creating them and running checkMesh, 9 severe errors appear and unfortunately, it is impossible to simulate with this mesh (floating point exception)
After modifying every single parameter in sHM's Dict with no successful results, I have decided to use subSetMesh utility, in order to create a topoSetDict and then, remove those cells so that my mesh passes successfully the mesh check and therefore, I will probably be able to simulate.
The problem is that I do not know how to select those cells. How could it be done? (I think the only needed aspect is the cell ID but I have no idea how to obtain just the IDs of the "bad" cells, does anyone know?)
This is the checkMesh output, just in case it helps:
Enabling all geometry checks.
Checking geometry...
    Overall domain bounding box (-0.225 -0.35 -0.125) (1.12 0.35 0.84)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (-5.87433e-16 6.97082e-17 -1.48306e-13) OK.
 ***High aspect ratio cells found, Max aspect ratio: 1.24904e+94, number of cells 35
  <<Writing 35 cells with high aspect ratio to set highAspectRatioCells
    Minimum face area = 5.21919e-10. Maximum face area = 0.00357495.  Face area magnitudes OK.
 ***Zero or negative cell volume detected.  Minimum negative volume: -6.5735e-10, Number of negative volume cells: 35
  <<Writing 35 zero volume cells to set zeroVolumeCells
    Mesh non-orthogonality Max: 179.989 average: 7.91616
   *Number of severely non-orthogonal (> 70 degrees) faces: 115.
 ***Number of non-orthogonality errors: 109.
  <<Writing 224 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 240 faces are incorrectly oriented.
  <<Writing 183 faces with incorrect orientation to set wrongOrientedFaces
 ***Max skewness = 16.2622, 20 highly skew faces detected which may impair the quality of the results
  <<Writing 20 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
 ***Error in face tets: 717 faces with low quality or negative volume decomposition tets.
  <<Writing 318 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces
    Min/max edge length = 2.07766e-05 0.0607762 OK.
   *There are 66069 faces with concave angles between consecutive edges. Max concave angle = 89.3598 degrees.
  <<Writing 66069 faces with concave angles to set concaveFaces
    Face flatness (1 = flat, 0 = butterfly) : min = 0.0400623  average = 0.999966
   *There are 86 faces with ratio between projected and actual area < 0.8
    Minimum ratio (minimum flatness, maximum warpage) = 0.0400623
  <<Writing 86 warped faces to set warpedFaces
    Cell determinant (wellposedness) : minimum: 9.01638e-05 average: 10.1297
 ***Cells with small determinant (< 0.001) found, number of cells: 4
  <<Writing 4 under-determined cells to set underdeterminedCells
 ***Concave cells (using face planes) found, number of cells: 590857
  <<Writing 590857 concave cells to set concaveCells
    Face interpolation weight : minimum: 0.01328 average: 0.478489
 ***Faces with small interpolation weight (< 0.05) found, number of faces: 11
  <<Writing 11 faces with low interpolation weights to set lowWeightFaces
    Face volume ratio : minimum: -10.9825 average: 0.902224
 ***Faces with small volume ratio (< 0.01) found, number of faces: 142
  <<Writing 142 faces with low volume ratio cells to set lowVolRatioFaces
Failed 10 mesh checks.
End
jet_engine is offline   Reply With Quote
Old   June 24, 2016, 10:31
Max Vorstadt
EDIT: I have found a tutorial for SetSet but it is not working either. It just gives me a non-3D mesh so that pimpleFoam cannot even start.
foamJob -s setSet -constant Command>list Command>cellSet bubu new cellToCell underdeterminedCells any Command>list Command>cellSet bubu add faceToCell concaveFaces any Command>cellSet bubu add faceToCell edgeFaces any Command>cellSet bubu add faceToCell warpedFaces any Command>cellSet bubu add faceToCell wrongOrientedFaces any Command>cellSet bubu invert Command>cellSet bubu subset Command>quit
And that is the output for some of the commands above (it looks like for the last 3 "any commands" it does not work:
Usage: faceToCell <faceSet> neighbour|owner|any|all  Select cells that are the owner|neighbour|any of the faces in the faceSet or where all faces are in the faceSet
It just generates a new time folder, a VTK folder and a couple of archives more, but if I try to reconstruct the mesh (maybe I am not doing it well either), pimpleFoam or any solver just crashes indicating that the mesh is not even 3D. And if I run checkMesh after setSet it is even worse in some error cases! (not all errors are deleted as it should...)
layers, mesh, snappyhexmesh, subsetmesh, toposet
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
[snappyHexMesh] snappyHexMesh: Bad snapping on shallow slopes matthiasd OpenFOAM Meshing & Mesh Conversion 5 February 1, 2017 18:23
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] snappyHexMesh matches wrong cells to CellZone Siegunn OpenFOAM Meshing & Mesh Conversion 4 July 31, 2015 06:10
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
