Rep Power: 13 ![]() |
Hello everyone. I am working on a domain which can be seen in the attached JPG file. There are two regions in my domain; as void and solid regions.
I am beginner level OpenFOAM user. I found a tutorial on meshing similar to my problem on the web page of one of the lab at Stanford University. Following their tutorial I am able to mesh fluid region by using blockMesh and snappyHexMesh but I need mesh on solid region too. How can I do that? What I need to do is, mesh both solid and fluid regions and name the mesh at the solid regions something like "Wall" so I can apply boundary condition on it. Till now, I did something similar to this: I have only one STL file for porous structure. I add bounding box to it and the regions outside of LocationInMesh point are named as FixedWall and left without meshing. Now, I need to mesh this region too and name it as fixedWall. Thank you so much. ![]() Final result that I want to obtain: ![]() Last edited by cfdsolver1; June 23, 2016 at 12:17. |
snappyhexmesh |
[snappyHexMesh] Problem with decomposePar, snappyHexMesh | luca1992 | OpenFOAM Meshing & Mesh Conversion | 12 | August 23, 2017 19:06 |
[snappyHexMesh] Problem handling with subdictionary in SnappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 0 | November 21, 2015 13:57 |
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model | Saideep | OpenFOAM Meshing & Mesh Conversion | 5 | May 10, 2015 14:46 |
[snappyHexMesh] Problem with snappyHexMesh | giack | OpenFOAM Meshing & Mesh Conversion | 2 | September 18, 2014 10:03 |
[snappyHexMesh] Problem with snappyHexMesh | giack | OpenFOAM Meshing & Mesh Conversion | 0 | March 7, 2014 09:40 |
