[snappyHexMesh] snappyHexMesh does not create mesh in body volume |
June 21, 2016, 11:50 |
Axel
Rep Power: 10 |
I am a new OpenFOAM and SHM user. I am trying to mesh a pipe segment with SHM. I created the geometry in Salome and exported all surfaces as stl files. SHM does not give any error message but somehow the interior of the mesh seems to be missing. Additionally the sharp edges are not meshed properly although surfaceFeatureExtract seems to have worked (I have included the feature line object in the images) I appreciate every help. Thanks in advance! Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; // make basic mesh ? snap true; // decide to snap back to surface ? addLayers true; // decide to add viscous layers ? geometry // Load in STL files here { Inlet.stl {type triSurfaceMesh; name Inlet;} Outlet.stl {type triSurfaceMesh; name Outlet;} Mantel.stl {type triSurfaceMesh; name Mantel;} All_Faces.stl {type triSurfaceMesh; name All_Faces;} }; castellatedMeshControls { maxLocalCells 1000000; //max cells per CPU core maxGlobalCells 10000000; //max cells to use before mesh deletion step minRefinementCells 10; //was 0 - zero means no bad cells are allowed during refinement stages maxLoadUnbalance 0.10; nCellsBetweenLevels 1; // expansion factor between each high & low refinement zone // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command features ( {file "Inlet.eMesh"; level 3;} {file "Outlet.eMesh"; level 3;} {file "Mantel.eMesh"; level 3;} ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces // Surface-wise min and max refinement level { Inlet {level (0 0);} Outlet {level (0 0);} Mantel {level (3 3);} } refinementRegions // In descending levels of fine-ness { All_Faces { mode distance; levels ((0.0002 4) (0.0004 3) (0.0008 2)); // was ((0.001 4) (0.003 3) (0.01 2)) } } resolveFeatureAngle 80; // Resolve sharp angles // Default 30 locationInMesh (0 0 0); //to decide which side of mesh to keep ** allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 3; tolerance 4.0; nSolveIter 30; nRelaxIter 5; nFeatureSnapIter 15; // default is 10 // New settings from openfoam 2.2 onwards for SHMesh implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract explicitFeatureSnap true; // default is true multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces } // Settings for the layer addition. addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName { relativeSizes false; // was true layers { Walls {nSurfaceLayers 3;} } expansionRatio 1.3; finalLayerThickness 0.0001; //was 0.00016 minThickness 0.00002; //was 0.00008 nGrow 0; // was 1 // Advanced settings featureAngle 80; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle. nRelaxIter 3; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh. nSmoothSurfaceNormals 1; // Number of smoothing iterations of surface normals nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction nSmoothThickness 10; // Smooth layer thickness over surface patches maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large minMedianAxisAngle 130; // Angle used to pick up medial axis points nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations nLayerIter 50; // Overall max number of layer addition iterations } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minFlatness 0.5; minVol 1e-13; minTetQuality 1e-9; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; // Advanced nSmoothScale 4; errorReduction 0.75; } // Advanced debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1E-6; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-1e-03 -4e-03 -4e-03) (15e-03 -4e-03 -4e-03) (15e-03 4e-03 -4e-03) (-1e-03 4e-03 -4e-03) (-1e-03 -4e-03 4e-03) (15e-03 -4e-03 4e-03) (15e-03 4e-03 4e-03) (-1e-03 4e-03 4e-03) ); blocks ( hex (0 1 2 3 4 5 6 7) (40 10 10) simpleGrading (1 1 1) ); edges ( ); patches ( patch minX ( (0 3 7 4) ) patch maxX ( (1 2 6 5) ) patch minY ( (0 4 5 1) ) patch maxY ( (2 3 7 6) ) patch minZ ( (0 1 2 3) ) patch maxZ ( (4 5 6 7) ) ); // ************************************************************************* // |
July 11, 2016, 22:35 |
Rep Power: 25 |
What does the surface mesh of your STL look like?
snappy hex mesh, surfacefeatureextract |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 06:09 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
