[blockMesh] Question: OpenFOAM 3.2 issue installing blockMeshDG
Old   June 10, 2016, 15:19
Default Question: OpenFOAM 3.2 issue installing blockMeshDG
Engineers is on a distinguished road
First let me state that I'm new to OpenFOAM world, and I'm training myself with small cases. The following question arose from a case of double wall channel flow using foam-extend-3.2. I have been trying to use the Multigrade capabilities of blockMesh with the following blockMeshDict:
convertToMeters 1;
vertices
(0 0 0)
(2 0 0)
(2 1 0)
(0 1 0)
(0 0 0.01)
(2 0 0.01)
(2 1 0.01)
(0 1 0.01)
blocks
hex (0 1 2 3 4 5 6 7) (100 50 1)
simpleGrading
1
((0.25 0.4 4) (0.5 0.2 1) (0.25 0.4 0.25))
1
edges
boundary
fixedWall
type wall;
faces
(0 1 5 4)
(3 2 6 7)
inlet
type patch;
faces
(0 3 7 4)
outlet
type patch;
faces
(1 5 6 2)
frontAndBack
type empty;
faces
(0 3 2 1)
(4 5 6 7)
mergePatchPairs
However, this does not work with the typical "blockMesh" command, which has an issue with the extra brackets in "block" section of the code"
wrong token type - expected Scalar found on line 37 the punctuation token '('
After some search online, I noticed that users of OF 2.1-2.2 had to install a new app "blockMeshDG" to be able to use the Multi-grading of a block. I tried installing blockMeshDG using the following commands that I found online:
wget https://bitbucket.org/akidess/blockmeshdg/get/tip.zip -O latest-blockmeshDG.zip
unzip latest-blockmeshDG.zip
cd akidess-blockmeshdg-*
chmod +x Allwmake
find . -exec touch '{}' \;
./Allwmake
However, I ended up with the following error while installing it:
blockMesh/blockMeshTopology.C:27:18: error: Time.H: No such file or directory
make: *** [Make/linux64GccDPOpt/blockMeshTopology.o] Error 1
Making dependency list for source file blockMeshApp.C
could not open file Time.H for source file blockMeshApp.C
could not open file attachPolyTopoChanger.H for source file blockMeshApp.C
could not open file slidingInterface.H for source file blockMeshApp.C
This is followed by over 30 lines of other errors.
Sorry for the long story... Would you happen to know what I'm doing wrong here?
Thanks
Engineers is offline   Reply With Quote
Old   November 10, 2016, 15:45
Rolanzo
Rolanzo is on a distinguished road
Hi, I am running the same issue, so I wonder if you managed to solve this problem?
Rolanzo is offline   Reply With Quote
Old   November 16, 2016, 15:51
Sorry, I did not get a solution for this problem.
Old   November 16, 2016, 17:08
Mikko
Flowkersma is on a distinguished road
As far as I know foam-extend's blockMesh does not support multi-grading. OpenFOAM 3 and 4 support multi-grading out of the box so for them there is no need to install any external applications. Obviously, you can create the multi-grading mesh with OpenFOAM and then use the resulting mesh with foam-extend.
Regards,
Mikko
Flowkersma is offline   Reply With Quote
Old   November 17, 2016, 04:10
akidess's Avatar
Anton Kidess
http://www.cfd-online.com/Forums/ope...tml#post561324
This post explains the problem. Another hint, compare the blockMeshTopology.C of blockMeshDG (see compiler error message) with the blockMeshTopology.C of your foam-extend installation. Probably at that point the fix will be easy for you.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 14:24
Installing OpenFOAM-1.6.x on OpenSUSE 11.2, A question to the developers Ahmed OpenFOAM Installation 0 December 5, 2009 06:03
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
