[mesh manipulation] extrudeToRegionMesh - direction into the domain
Old   June 10, 2016, 07:54
Default extrudeToRegionMesh - direction into the domain
Nicklas Linder
nlinder is on a distinguished road
Hi guys,
I want to generate a Region at a boundary tu use the filmModel. The tutorial cylinder generates a one cell thick region by extrudeToRegionMesh which points into the domain.
OF v2.4.0:
I set up a simple case with a sphere in the center of the domain and fluid around. I use topoSet to select the boundary faces and generate a faceZone. This faceZone is handed to extrudeToRegionMesh to generate the region. This basically works, but the region points into the sphere - so out of the domain. I tried to use "flip true" in the topoSet, but this did not help. I also switched manually the normal in constant/polyMesh/faceZone. This generates the region in the domain, but then, the mapping of the two regions does not happen.
So I am stuck here, does anyone had the same experience and an idea for a solution?
Thanks
Nicklas
nlinder is offline   Reply With Quote
extrudetoregionmesh
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
confusion in specifying domain flow direction and results ashwani.thakur CFX 4 February 28, 2015 07:45
Heat transfer within a porous domain rbezerra CFX 5 January 9, 2015 06:06
Recommended domain size in Z direction aamer Main CFD Forum 0 December 22, 2010 06:57
