[snappyHexMesh] snappyHexMesh creating a box inside my geometry (not supposed to do so!)
Old   June 6, 2016, 10:10
Default snappyHexMesh creating a box inside my geometry (not supposed to do so!)
Rafael
ocalloc is on a distinguished road
I'm trying to mesh a geometry from an .stl file. The geometry is a "boat"(more like a shoebox) with two tanks inside (more shoeboxes). The outer tank is connected to the outside by a big hole, and the inner tank is connected to the outer tank by three small cylinders.
I was having problems to mesh the geometry because the 3 cylinders were too small compared to the rest of geometry, and he didn't mesh it. I've changed the refinement boxes and it meshed all the structure. But now it appeared a box inside the inner tank!
I don't know if it is a bug or a problem with my meshing parameters.
I'm attaching 3 pictures to better explain this problem, and also the files to mesh it by yourselves.
Thanks
Ps: for meshing you've got to run:
blockMesh
surfaceFeatureExtract
topoSet
snapyHexMesh -overwrite
File Type: jpg Screenshot from 2016-06-06 11:30:46.jpg (185.3 KB, 40 views)
File Type: jpg Screenshot from 2016-06-06 11:32:01.jpg (130.6 KB, 30 views)
File Type: jpg Screenshot from 2016-06-06 11:32:36.jpg (176.4 KB, 27 views)
File Type: jpg Screenshot from 2016-06-06 11-30-46.jpg (162.9 KB, 28 views)
ocalloc is offline   Reply With Quote
Old   June 8, 2016, 12:45
Rafael
Hi.
I've tried to separate the geometries to see if that could solve the problem, but it persists.
With each part of the geometry, it comes a face of the undesired box.
Only the cylinders come free of undesired faces.
I'm attaching some images and the files for meshing by parts.
Anyone has any idea why this is happening???
Thanks
File Type: jpg Screenshot from 2016-06-08 16:37:16.jpg (147.1 KB, 13 views)
File Type: jpg Screenshot from 2016-06-08 16:37:50.jpg (120.5 KB, 14 views)
File Type: jpg Screenshot from 2016-06-08 16:38:50.jpg (132.3 KB, 13 views)
File Type: jpg Screenshot from 2016-06-08 16:39:44.jpg (94.5 KB, 10 views)
Old   June 9, 2016, 11:04
Rafael
Hi.
I managed to solve the problem by increasing the level on the surfaces.
Thanks
bug, mesh, snappyhexmesh
[ANSYS Meshing] Meshing inside geometry lenzo ANSYS Meshing & Geometry 1 December 21, 2016 01:35
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
[DesignModeler] POROUS Media inside a pipe geometry creation gauravchauhan ANSYS Meshing & Geometry 0 April 12, 2014 05:15
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[snappyHexMesh] snappyHexMesh, complex geometry nakor OpenFOAM Meshing & Mesh Conversion 1 June 7, 2013 02:35
