[snappyHexMesh] ExtrudeMesh+Snappy: meshing an annular sector |
June 3, 2016, 05:56 |
Joris C.
Rep Power: 13 |
I am having problems with creating a mesh generated by snappy for an annular sector problem. The annular sector has only 1 cell in the rotational direction (2D), so I use snappy on a 3D problem and then extrudeMesh:
blockMesh >> logFile surfaceFeatureExtract >> logFile snappyHexMesh -overwrite >> logFile extrudeMesh >> logFile What does work however is creating a wedge. Therefore, the following tutorial works brilliantly: http://www.holzmann-cfd.de/index.php.../2d-wedge-mesh It has to be slightly adapted for OpenFoam 3.0, by changing the wedgeCoeffs entry in extrudeMeshDict to sectorCoeffs. For an annular sector, I moved the .stl of the tutorial case 0.05 m away from the axis of rotation. I also did a surfaceOrient such that the normals on the stl surfaces point in the same direction as the original .stl. However, as said, the extrudeMesh returns an empty mesh. Snappy works just fine. My case is in the attachment. I am using OpenFoam 3.0.1 on Ubuntu. Any thoughts? |
extrudemesh, sector, wedge |
Partition does not start on physical sector boundary!!?? | immortality | Lounge | 1 | December 8, 2013 15:04 |
[ICEM] Problem Meshing a Cylindrical sector in ICEM | SRead | ANSYS Meshing & Geometry | 4 | July 18, 2012 14:10 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
