[Other] solid deformed geometry for fluid meshing?
Old   May 30, 2016, 10:22
Question solid deformed geometry for fluid meshing?
Florian Nguyen
Awak is on a distinguished road
Hello foamers,
I am interested in the flow coming inside a tube through a reed valve. I have been having a lot of trouble on running two-way FSI simulations on this topic, so I thought I would try to do the following:
- using a steady solid solver, calculate the displacement of the valve
- export the valve deformed mesh as a STL with surfaceMeshTriangulate or something similar
- use this STL along with another "fixed wall + outlet + inlet" STL defining the rest of my geometry as an input for snappyHexMesh
- solve the fluid with a steady/transient compressible solver
My approach is different from the few FSI cases that I've seen so far: I don't want to deform my mesh, but rather to generate my static mesh on a deformed geometry.
Currently I am having trouble defining my CAD geometry. Both my fluid and solid surfaces are manifold, but is it possible to assemble them together by specifying a common face? Or will SHM return an error? Could you please tell me how to do this?
If any of you has some advice for me it's most welcome! Thank you for your help!
Florian
Awak is offline   Reply With Quote
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. hda ANSYS Meshing & Geometry 5 October 24, 2016 10:26
[ICEM] Creating mesh for fluid - solid geometry tmu ANSYS Meshing & Geometry 1 March 5, 2016 07:14
Import Deformed Geometry into Fluent lgamble FLUENT 1 February 25, 2016 14:59
[GAMBIT] spray dryer geometry meshing gambit deepak11091 ANSYS Meshing & Geometry 1 October 29, 2015 03:07
[Workbench] Meshing and export mesh from STL geometry alerfreire ANSYS Meshing & Geometry 0 March 26, 2013 10:25
