[snappyHexMesh] SnappyHexMesh in parallel missing 0 folder |
May 26, 2016, 22:46 |
LD
Rep Power: 10 |
I have hit a roadblock recently and can't seem to find a way out.
Situation: snappyhexmesh, when run in parallel, does not have 0 folder in processor* folder. Please see my attached Allrun file. However, when I run the motorbike tutorial's Allrun file, the 0 folder is created. Please see attached Allrun files from the two cases. I have also attached some other dict files in case they might help. What am I doing wrong here? Can someone help? |
snappyHexMesh in parallel leads to segmentation fault | ChrisHa | OpenFOAM Pre-Processing | 1 | January 14, 2019 10:04 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 07:43 |
[snappyHexMesh] Folder structure from snappyHexMesh | elisenda | OpenFOAM Meshing & Mesh Conversion | 3 | January 6, 2010 03:52 |
