[Other] Mesh for 2D axis symmetric wedge domain with stenosis |
April 17, 2016, 13:38 |
Bentley Lam
Rep Power: 10 |
Hi all,
Can anyone give me guidelines on how to create such a domain using blockmesh? (Please see attached picture) I am able to create the wedge domain, however I am unable to add the stenosis (reduction of cross section area). Really appreciated for any help! Bentley. |
April 17, 2016, 14:37 |
Alex
Rep Power: 12 |
I'd suggest you create three blocks:
1. upstream of the stenosis 2. stenosis 3. downstream this way you can introduce the stenosis part with its block vertices and then under 'edges' define two arcs for the curved part (see arc in user guide). shouldn't be too difficult. Don't forget the definition of the cyclic wall patches in case you haven't already done it. Cheers Alex |
April 18, 2016, 07:12 |
Bentley Lam
Rep Power: 10 |
Alex, Thank you! I will have a try on this and post my mesh if I can make it!
April 18, 2016, 09:53 |
Bentley Lam
Rep Power: 10 |
Done! Thanks. However, I am using "polyLine" to put a cosine curve there
April 18, 2016, 11:32 |
Alex
Rep Power: 12 |
I'm glad you got it to work! Depending on your number of coordinate points for the curve, "spline" may give you a little softer surface.
Cheers Alex |
[blockMesh] Problems in creating a wedge type mesh | Joscha | OpenFOAM Meshing & Mesh Conversion | 28 | August 3, 2019 08:59 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 04:14 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 05:49 |
