[Commercial meshers] ccm26toFoam double free or corruption
Like Tree1Likes
Old   April 19, 2017, 14:45
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
It is unlikely, that the line, you have posted, causes Floating Point Exception. As soon as you post stack trace with line numbers it would be easier (maybe the problem in fact is in libccmio and not in converter.
According to your output error happens somewhere between line 667 and 708 (otherwise you get output containing nPoints). Between these two lines there are calls to CCMIOReadProcessor and ReadCells, correct backtrace can show, which one causes FPE.
alexeym is offline   Reply With Quote
Old   October 9, 2023, 09:14
Jazz Wu
littleJazz is on a distinguished road
Originally Posted by abe View Post
Thank you alexeym. I am really grateful for your comment. I used the debug version I was provided. I am compiling another version myself.
However, I guess the problem comes from the number of faces as in the mesh I am trying to convert:
95187700 cells, 612345350 faces, 502047784 verts.
And the crashes happens at:
List<label> ccmFaces(size);
/Regards
Hi, Abe
Did you solve this problem? I have the same problem as you. Specifically, the ccm26toFoam will complain "core dumpFloating point exception (core dumped)" when the mesh size is tens of millions. A small number of mesh is ok.
Could you give me some help?
Best regards,
Jazz
littleJazz is offline   Reply With Quote
New densitybased solver AeroFoam giulio_romanelli OpenFOAM Running, Solving & CFD 48 January 15, 2016 09:20
wired error in sprayFoam conceptone OpenFOAM 8 June 21, 2012 17:41
PtrList of lagrangian clouds: double free or corruption crash mturcios777 OpenFOAM Programming & Development 4 February 15, 2012 15:32
ReactingFoam Error sahm OpenFOAM 4 August 20, 2010 16:22
A stupid question luckyluke OpenFOAM Running, Solving & CFD 14 August 13, 2007 05:25
