[snappyHexMesh] Doubts about how larger mesh done with blockMesh affects boundaries in snappyHexMesh |
April 12, 2016, 04:52 |
rosario
Hi guys,
I am a new openFoam user and I m trying to use Snappymesh. I am not sure I got it right but I understood that in the blockmesh I should create a block that is bigger than the object i want to snap. Is it right? If this is the case, how does openFoam know which are my boundary conditions in the object if they are defined based on the simple block in the blockmesh file? Thanks for your help, Rosario |
April 28, 2016, 05:34 |
Rep Power: 10 |
Hi Rosario,
It is right. I suggest to have a look at the motorbike tutorial for example, it will help you to understand how to set up your case. Hope it helps mqsim |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh | czhongrong | OpenFOAM Meshing & Mesh Conversion | 1 | January 20, 2016 05:26 |
[snappyHexMesh] How to create internal boundaries using snappyHexMesh | robyTKD | OpenFOAM Meshing & Mesh Conversion | 2 | October 19, 2014 09:57 |
[ICEM] Extruded unstructured mesh association with boundaries, volumes, etc. | macfly | ANSYS Meshing & Geometry | 6 | August 7, 2012 16:13 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
