[Gmsh] Problem with mesh conversion from gmsh
Old   April 12, 2016, 11:54
Default Problem with mesh conversion from gmsh
A Russell
arussell92 is on a distinguished road
I have created a mesh in gmsh and am trying to convert it to openfoam format using gmshToFoam. However I keep getting the error as shown below, any suggestions as to how to fix the problem?
[ofuser@boot2docker Sun_val]$ gmshToFoam /home/ofuser/workingDir/FoamCases/Sun_v
al/validation.mshh
| \\ / O peration | Version: v3.0+ |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : v3.0+-e941ee6c15e9
Exec : gmshToFoam /home/ofuser/workingDir/FoamCases/Sun_val/validation.msh
Date : Apr 12 2016
Time : 14:47:27
Host : "boot2docker"
PID : 202
Case : /home/ofuser/workingDir/FoamCases/Sun_val
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMas
ter
allowSystemOperations : Allowing user-supplied system call operations
Create time
Starting to read mesh format at line 2
Read format version 2.2 ascii 0
Starting to read physical names at line 5
Physical names:6
Surface 1 backwall
Surface 2 frontWall
Surface 3 outlet
Surface 4 inlet
Surface 5 bottomWall
Surface 6 topWall
Starting to read points at line 14
Vertices to be read:350400
Vertices read:350400
Starting to read cells at line 350417
Cells to be read:524253
Mapping region 1 to Foam patch 0
Mapping region 3 to Foam patch 1
Mapping region 6 to Foam patch 2
Mapping region 4 to Foam patch 3
Mapping region 5 to Foam patch 4
Mapping region 2 to Foam patch 5
Mapping region 1000 to Foam cellZone 0
--> FOAM FATAL IO ERROR:
Attempt to get back from bad stream
file: IStringStream.sourceFile at line 0.
From function bool Foam::Istream::getBack(Foam::token&)
in file db/IOstreams/IOstreams/Istream.C at line 56.
FOAM exiting
arussell92 is offline   Reply With Quote
Old   April 12, 2016, 12:23
A Russell
Had been trying to convert a 2D mesh to 3D via an extrusion to be run as 2D in openfoam so had been defining the layers in the extrusion to 1 however this did not work. Having increased the number of layers to 10 the mesh appeared to convert correctly and checkMesh returned that the Mesh was ok.
Therefore how do you run a 2D simulation in openfoam if the mesh has more than 1 layer in the z-direction?
Old   April 12, 2016, 13:05
A Russell
Found the problem it seems. GMSH was taking a while to save the mesh and I hadn't noticed this and so think I may have been copying the file to the case folder before it had finished saving the mesh file.
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 14:28
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Gmsh] problem converting mesh from gmsh Fried OpenFOAM Meshing & Mesh Conversion 8 October 18, 2011 09:53
