[snappyHexMesh] boundary layer on a curvy 3D cylindrical surface - snappyHexMesh |
April 4, 2016, 05:02 |
ravi chaithanya
I am unable to get a boundary layer on the curved cylinder as attached. Where as I am able to get the boundary layer on a perfect cylindrical surface. Kindly help. The curvy surface is attached. Below are the details of snappyHexMesh /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; geometry { cylinder.stl { type triSurfaceMesh; name riser; } boxA { type searchableBox; min (-6 -10 -2); max ( 20 10 12); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters // ~~~~~~~~~~~~~~~~~~~~~ maxLocalCells 100000; maxGlobalCells 1400000; minRefinementCells 0; nCellsBetweenLevels 1; features (); refinementSurfaces { riser { // Surface-wise min and max refinement level level (3 3); regions{“*.inlet|*.outlet”{level(3,4);}} } } // Resolve sharp angles on fridges resolveFeatureAngle 30; refinementRegions { boxA { mode inside; levels ((1e15 3)); } riser { mode distance; levels ((0.5 4));// (0.025 3)); } } locationInMesh (-6 0 0); allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 3; tolerance 4.0; nSolveIter 30; nRelaxIter 5; } // Settings for the layer addition. addLayersControls { relativeSizes true; layers { "riser.*" { nSurfaceLayers 20; } } expansionRatio 1.02; finalLayerThickness 0.4; minThickness 0.2; relativeSizes true; nGrow 0; featureAngle 30; nRelaxIter 5; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1e-13; minTetQuality 1e-30; minArea -1; minTwist 0.05; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } // Advanced // Flags for optional output // 0 : only write final meshes // 1 : write intermediate meshes // 2 : write volScalarField with cellLevel for postprocessing // 4 : write current intersections as .obj files debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; // ************************************************** *********************** // Thanks. |
April 6, 2016, 13:18 |
Have you tried with a lower nSurfaceLayers ?
Rep Power: 11 |
Have you tried with a lower nSurfaceLayers ? Let's say 5 for example ?
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
[snappyHexMesh] Triangular elements in boundary layers generated by snappyHexMesh | mike.franky | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2018 10:46 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
