[mesh manipulation] creating circular inlet on sqare wall |
March 24, 2016, 10:01 |
Hi foamers,
I'm trying to set up a mesh for a combustion model and have a problem in placing a cricular inlet on the front wall of the rectangular burner. After searching for a while I think topoSet and createPatch are the utilities I need, but I don't get it work. So how can I define a circular geometry in topoSet? After cylinderToCell I'm very baffled. Maybe someone knows how to slove this problem? Thank you very much in advance! Here's my blockMeshDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0, Ursprung, FRONT (0.2 0 0) //1, x_1-Wert, FRONT (0.2 0.2 0) //2, y_1-Wert, FRONT (0 0.2 0) //3, z_1-Wert, FRONT (0 0 2.5) //4, Ursprung, BACK (0.2 0 2.5) //5, x_2-Wert, BACK (0.2 0.2 2.5) //6, y_2-Wert, BACK (0 0.2 2.5) //7, z_2-Wert, BACK ); blocks ( hex (0 1 2 3 4 5 6 7) (35 35 251) simpleGrading (((1 0.23 1) (1 0.54 1) (1 0.23 1)) ((1 0.23 1) (1 0.54 1) (1 0.23 1)) 1) ); edges ( ); boundary ( front { type patch; faces ( (0 3 2 1) ); } back { type patch; faces ( (4 5 6 7) ); } Seiten { type wall; faces ( (0 1 5 4) (3 2 6 7) (1 5 6 2) (0 4 7 3) ); } ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( // front { name roundCells; type cellSet; action new; source cylinderToCell; sourceInfo { p1 (0.088 0.088 0); // start point on cylinder axis p2 (0.112 0.112 0); // end point on cylinder axis radius 0.012; } } { name frontSet; type faceSet; action new; source cellToFace; sourceInfo { set roundCells; option all; } } { name frontSet; type faceSet; action subset; source boxToFace; sourceInfo { box (0.088 0.088 0)(0.112 0.112 0); } } { name roundCells1; type cellSet; action new; source cylinderToCell; sourceInfo { p1 (0.088 0.088 0); // start point on cylinder axis p2 (0.112 0.112 0); // end point on cylinder axis radius 0.012; } } { name frontSet1; type faceSet; action new; source cellToFace; sourceInfo { set roundCells1; option all; } } { name frontSet1; type faceSet; action subset; source boxToFace; sourceInfo { box (0.088 0.088 0)(0.112 0.112 0); } } { name front; type faceZoneSet; action new; source setToFaceZone; sourceInfo { faceSet frontSet; } } { name front1; type faceZoneSet; action new; source setToFaceZone; sourceInfo { faceSet frontSet1; } } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync true; // Patches to create. patches ( { name inletA; patchInfo { type cyclicAMI; neighbourPatch inletB; coupleGroup inlet; } constructFrom set; set front; } { name inletB; patchInfo { type cyclicAMI; neighbourPatch inletA; } constructFrom set; set front1; } { name outlet; patchInfo { type empty; } constructFrom patches; patches (back); } ); // ************************************************************************* // |
March 24, 2016, 10:22 |
Vinícius da Costa Ávila
Rep Power: 11 |
Hi, it's most likely not the best solution, but if it takes too long for someone to give you the right answer and for you to manage to do your circular inlet, I would recommend to create your mesh with other software and then export to OpenFOAM. I usually do that with ICEM (Ansys) or Gmsh(free software), I think they are easier since they have a graphical interface to set up geometry and meshes.
Best luck
Vinícius dC.A. |
March 24, 2016, 10:32 |
Rep Power: 16 |
You are creating patches from faceZoneSets instead of faceSets. Have you tried it with the faceSets? Cheers, Antimony |
March 24, 2016, 11:57 |
thanks for your answers. Yes I tried with the faceSets, but the result remains the same. And when deactivating the subsets I get this error: Code:
--> FOAM FATAL ERROR: Face 1193 specified in set frontSet is not an external face of the mesh. This application can only repatch existing boundary faces. From function createPtch.exe in file createPatch.C at line 749. FOAM exiting |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
creating square patch (for air inlet) on the bottom face using cellset in toposet | Rajesh Nimmagadda | OpenFOAM Running, Solving & CFD | 0 | October 31, 2017 13:27 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Inlet and outlet boudary without wall between | Janshi | CFX | 5 | February 2, 2012 05:51 |
