[Other] Why shadow wall not showing in OpenFoam |
March 21, 2016, 06:03 |
Prasanna Welahettige
Rep Power: 10 |
I generate the Mesh in Ansys Fluent to export to OpenFom. The geometry contains a zero thickness wall.As boundary I named this as "wall". When I 'm simulating this in Ansys Fluent this zero thickness wall is recognize as "wall" and "shadow wall". Becase it is considering same elements for both side. But when I'm simulating this in OpenFoam the mesh is not giving shadow boundary. I need to know the reason for this ? Thanks. |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 07:23 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall | sebastian | OpenFOAM Meshing & Mesh Conversion | 6 | October 21, 2010 05:36 |
