[snappyHexMesh] Calculating Y+ & understanding the Snappyhexmesh log file |
March 14, 2016, 21:51 |
Rep Power: 16 |
I'm trying to work out the Y+ values I'm getting from created meshes.
Looking at the log file I see: patch faces layers overall thickness ...................[m].....[%] ----- ----- ------ --- --- Wing 1936859 0.883 0.000926 79.4 I'm guessing the 0.000926m value is the final layer thickness? What does the 79.4% mean? Are the contents of the log file documented somewhere? I've been unable to find it, if it is a link in that direction would be great. Thansks. |
April 26, 2016, 09:31 |
Rep Power: 10 |
Hi Doug68,
Did you find an answer to your issue? |
April 26, 2016, 21:17 |
Rep Power: 16 |
No I did not find a decent answer, frankly I think the documentation of OF is not that good there's a few things I've just come to a dead end on trying to work out.
As for Y+ there's a post processing function "yPlus" that'll create data you can use in paraFoam. I'm not sure if this is actually creating Y+ or Y*. Looking at the data and doing the math by hand to calculate Y+ some of the figures it presents look suspiciously small, so I'm not that confident in that either. |
April 27, 2016, 05:41 |
Rep Power: 10 |
I have not seen a better way than doing the math by hand for Y+ for the moment... At least we will be sure of what we have and no need to dig into OF documentation
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
