[mesh manipulation] Error for refineMesh
Old   March 14, 2016, 11:49
Exclamation Error for refineMesh
Mohsen
mohsen.boojari is on a distinguished road
I'm trying to run a test case but I'm facing with this Error . can anyone help me??
Thanks
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/mohsen/Desktop/NREL5MWRef/-overwrite at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
mohsen.boojari is offline   Reply With Quote
Old   March 15, 2016, 21:08
Antimony is on a distinguished road
Look at your function call. It seems like you are calling refineMesh with -overwrite as the file name.
What exactly was your function call (with arguments)?
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   April 4, 2016, 16:09
Mohsen
Originally Posted by Antimony View Post
Cheers,
Antimony
this is My Allrun script :
refineMeshByCellSet()
   while [ $# -ge 1 ]
   do
      cp system/topoSetDict.$1 system/topoSetDict
      if [ -f log.topoSet.$1 ]
      then
         echo "topoSet level $1 already run on $PWD: remove log file to re-run"
      else
         echo "creating cell set for primary zone - $1"
         runApplication topoSet
         mv log.topoSet log.topoSet.$1
      fi
      if [ -f log.refineMesh.$1 ]
      then
         echo "refineMesh level $1 already run on $PWD: remove log file to re-run"
      else
         echo "refining primary zone $1"
         runApplication refineMesh -dict -overwrite
         mv log.refineMesh log.refineMesh.$1
      fi
      shift
   done
runApplication blockMesh
refineMeshByCellSet 1 2 3 4
runApplication checkMesh
Old   April 4, 2016, 22:30
It would seem that the problem stems from the -dict tag. Once you specify the -dict tag, OF expects the location of the dictionary file to follow it. In your case, instead of the location of the dictionary file, there is the -overwrite tag and so OF goes looking for a dictionary file called "-overwrite".
So a solution would be to specify the location of the dictionary file after the -dict tag and then specify the -overwrite tag.
Hope this helps.
Cheers,
Antimony
Old   April 5, 2016, 01:48
Mohsen
Dear Antimony, Thanks for your help . it worked
error, refine mesh
