[Commercial meshers] Separating regions Problem after importing from Fluent Mesher
Old   March 1, 2016, 08:42
Default Separating regions Problem after importing from Fluent Mesher
Peter Hess
peterhess is on a distinguished road
Hello everybody,
I imported a multi-Regions Mesh from Fluent (Ansys) Mesher via command:
fluent3DMeshToFoam
It works well until here...
To separate the regions from each other I used the command:
splitMeshRegions -cellZones -overwrite
This one made also the job partly done.
The Problem is, after using this command, all the regions, that are physically separated, has been also separated and named separately...
Actually, some of them belongs to the same region and have also the same name by importing and are connected to the same neighbours...
- Should the command not collect them (the regions with the same name during importing) to one region? How could I fix that?
- How could I recollect those regions to just one again?
Thanks for your support
Peter
peterhess is offline   Reply With Quote
Old   March 1, 2016, 09:45
Default Problem Solved
Peter Hess
Using the command:
splitMeshRegions -cellZonesOnly -overwrite
solved the problem.
This command seems to separates the regions by name and not by walking through and searching the connection between the regions...
thanks
Peter
Stefan problem using fluent Isaacibp1401 Fluent Multiphase 2 June 7, 2021 06:49
problem while importing file from chemkin to ansys in fluent srinathsol CFD Freelancers 0 June 12, 2017 08:33
Importing CFX to FLUENT ckbenjamin ANSYS 1 June 26, 2011 19:10
Problem with ICEM and Fluent: Automatically created Regions within the domain sandmike_83 ANSYS Meshing & Geometry 0 September 24, 2010 06:42
A problem about Importing mesh from fluent aderliner OpenFOAM Running, Solving & CFD 0 December 19, 2006 00:00
