[snappyHexMesh] Can't see layers in paraView
Old   February 27, 2016, 13:54
Default Can't see layers in paraView
Francisco
Bollonga is on a distinguished road
Hello everyone,
I am trying to run a very simple 2D case of flow around a cylinder. I do blockMesh and then snappyHexMesh to finally apply extrudeMesh to get a 2D mesh.
The issue is I don't know why I cannot visualize the 3 layers around the cylinder in using paraFoam. Even if I make a cut plane.
I've checked the log file and layers have been made. Any one know why I cannot see them in paraView?
Please find attached the blockMeshDict, snappyHexMeshDict and log of the sHM.
Cheers,
Bollonga is offline   Reply With Quote
Old   March 7, 2016, 13:22
mohsen ari.
arianam is on a distinguished road
Hi Francesco!
Try this!
I think you need to run SHM two times!
First make the addLayers switch inactive!
run SHM
then make the first two(castellated and snap) inactive and activated addLayer switch.
Run SHM again
et voila!
Small point: check the final thickness of you layers!
arianam is offline   Reply With Quote
Old   November 7, 2018, 06:35
Kevin Habrock
Kevin.H is on a distinguished road
Hello Foamers
I am currently trying to convert my 3D model into a 2D model to reduce the computing time. The problem is that in the 2D case I can't see my Prism layers anymore or the command "extrudeMesh" just ignored them.
Is there a way to check without ParaFoam whether the PrismLayers still exist after the "extrudeMesh" command?
Do you have a solution for the problem?
Best regards
Kevin
Kevin.H is offline   Reply With Quote
Old   December 13, 2019, 11:02
Rasmus Iwersen
Rasmusiwersen is on a distinguished road
Originally Posted by Kevin.H View Post
Hello Foamers
Best regards
Kevin
Did you find a solution? I am trying to do the same (in 3D), and at a certain firstlayerthickness, i simply cannot visualize the boundary layer anymore in paraview. When firstlayerthickness is 0.15, 0.015 respectively, no problems. When setting it to 0.0015 is disappears, and in the log.snappyHexMesh file the thickness is equated to zero... Any ideas?
In fact, do you have the snappyHexMesh file from the first picture you posted (3D?). This is quite exactly what i am looking for.
Rasmusiwersen is offline   Reply With Quote
addlayers, paraview, shm, snappyhexmesh
[OpenFOAM] Checking layers generated by snappy with paraview bentkj ParaView 1 February 22, 2018 04:32
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 06:48
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 14:24
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 03:32
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
