February 25, 2016, 12:04 |
Double grading meshes
Tom Bale
Hi All,
I've just started using openFoam and I'm looking to change my mesh using double grading. This sentence is in the wiki, "Each of the grading sections is described by a triple consisting of the fraction of the block, the fraction of the divisions and the grading ratio" and I was wondering what the fraction of the divisions is? |
February 25, 2016, 22:30 |
Rep Power: 16 |
A typical block definition goes something like this: hex (0 1 2 3 4 5 6 7) (NX NY NZ) simpleGrading ( 1 ( (LY1 ny1 GR) (LY2 ny2 GR) ) 1 ) Basically these should hold: LY1 + LY2 = Span in the y-direction of the mesh ny1 + ny2 = NY i.e. the sum of the number of cells in each sub-block should equal the total number of cells of the big block. Hope this helps. Cheers, Antimony |
fvOptions | npatricia | OpenFOAM | 6 | May 23, 2018 06:21 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 08:31 |
Warning message C4133 while compiling | Arminius | Fluent UDF and Scheme Programming | 0 | October 2, 2017 12:44 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
