[mesh manipulation] mirrorMesh Problems
Old   February 24, 2016, 06:27
Default mirrorMesh Problems
Joćo Coelho
jlbbcoelho is on a distinguished road
Hi all,
I work on case with multi regions. Since the problem involves radiation (fvDOM model), I used the symmetry patch to simplify my geometry and improve the simulation times. But I not achieve the results I expected.
So to try understand the problem I want simulate all geometry instead of the symmetry version. To do that I used the the mirrorMesh application included on OF 2.3.0. The mesh also need to be axisymmetric and I used the third party application makeAxialMesh to convert it.
So far so good, my probleme is when I run the simulation, the solver (chtMultiRegionSimpleFoam) only run on the original mesh, and nothing happen on the mirror mesh. If I open on Paraview I can see the mesh as one, but the results are only showed and calculated on the original mesh.
Someone can help me, or a clue...
Thanks in advance for yuor time
Ps: English is not my mother language, so sory for some mistake in above message
Cheers
Joćo Coelho
jlbbcoelho is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
