February 13, 2016, 17:03 |
Gmsh conversion but error in paraview
Lewis
Rep Power: 10 |
Hi all
I've created a mesh around an aerofoil in gmsh, and converted it to OpenFOAM via the gmshToFoam command which came out with the following warning: --> FOAM Warning : From function polyMesh:olyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 627 Found 69421 undefined faces in mesh; adding to default patch. but used checkMesh, terminal told me: Checking geometry... Overall domain bounding box (-5 -4 0) (5 4 1) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (1.12865e-18 -8.92402e-18 -3.0121e-15) OK. Max cell openness = 1.86858e-16 OK. Max aspect ratio = 880.922 OK. Minimum face area = 5.43055e-06. Maximum face area = 0.277767. Face area magnitudes OK. Min volume = 5.43055e-06. Max volume = 0.0247845. Total volume = 79.9177. Cell volumes OK. Mesh non-orthogonality Max: 38.9542 average: 7.75624 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.559458 OK. Coupled point location match (average 0) OK. Mesh OK. End And so I finally called the command paraFoam, to check the mesh in paraview and when selecting the meshed parts and clicking apply, I get thrown out of paraview and get this returned to me in the terminal: --> FOAM FATAL IO ERROR: Cannot find patchField entry for front file: /home/lwsedgeworth/OpenFOAM/lwsedgeworth-2.4.0/run/fyp/AeroFoam/Tutorials-2.4.0/incompressible/AeroFoam/0/p.boundaryField from line 26 to line 50. From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209. FOAM exiting Segmentation fault (core dumped) Any ideas whatsoever are very welcome! |
February 14, 2016, 04:15 |
Names of boundaries in your mesh (msh file) and in your initial/boundary conditions (files in 0 folder) are out of sync. Just like the error message said: Code:
Cannot find patchField entry for front file: /home/.../AeroFoam/0/p.boundaryField from line 26 to line 50. |
February 15, 2016, 06:46 |
Lewis
Rep Power: 10 |
Thank you very much! I forgot about the files in the 0 directory, too busy trying to get the mesh sorted.
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[Gmsh] Rendering gmsh files in ParaView | doyled | OpenFOAM Meshing & Mesh Conversion | 2 | July 25, 2014 23:11 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
