[snappyHexMesh] blade edges deleted by snappyHexMesh |
February 9, 2016, 05:33 |
M. Salman Siddiqui
Rep Power: 11 |
Hey.
I plan to do a complete 3D simulation of NREL 5MW wind turbine. For that i am using propeller case in open Foam as the base line case. I generated the complete 3D.stl file for the turbine rotor and use the concept of AMI patches to simulate the turbine. However, the mesh on the surface of blade is not good. Even though i am using the utility surface feature extract, the SMH keep on deleting some parts on the surface of turbine blade. Does anybody have any idea why it is happening like this? Please let me know what parameters i need to play with to get rid of this problem. Also i think when i run SMH in parallel the mesh is more weird than in a serial configuration. I have attached the pictures to get a better idea of what snappyHexmesh is doing. |
August 9, 2016, 08:13 |
Cameron
Rep Power: 14 |
That's almost certainly a refinement issue. Either decrease the cell size of your background mesh or increase the maximum surface refinement in snappy hex mesh, specifically this line:
refinementSurfaces { wing { // Surface-wise min and max refinement level level (2 5); // increase the second number } } |
edge mesh, snappy hex mesh, surfacefeatureextract |
[snappyHexMesh] snappyHexMesh does not find intersected edges | Seb_Ve | OpenFOAM Meshing & Mesh Conversion | 2 | July 19, 2018 09:50 |
[snappyHexMesh] Jagged edges after snappyhexmesh around cylinder | vaibhav.antil | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2015 14:36 |
[snappyHexMesh] SNappyHexMEsh and GGI (standing mesh gets deleted) | A.Wendy | OpenFOAM Meshing & Mesh Conversion | 1 | August 2, 2013 07:04 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 22:43 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
