[Commercial meshers] Gambit to foam
Old   February 7, 2016, 12:51
Default Gambit to foam
Fatemeh
fatemehfarshi62 is on a distinguished road
Hi every one. I want to export a 3d mesh from gambit to foam. Would anyone please tell me if I need the blockMeshDict file any more? Thanks
fatemehfarshi62 is offline   Reply With Quote
Old   March 12, 2016, 11:56
Artur's Avatar
Artur
Artur will become famous soon enough
blockMeshDict is only needed if you're going to run blockMesh on the case, if you are using an external meshing tool you may safely remove it.
A
Artur is offline   Reply With Quote
Old   March 13, 2016, 03:16
Fatemeh
Thanks so much for your help
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
[Commercial meshers] gambit mesh to Foam problem AmirBaqa1987 OpenFOAM Meshing & Mesh Conversion 1 May 19, 2013 06:26
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
