[Gmsh] gmshtofoam error
Old   February 3, 2016, 12:25
Default gmshtofoam error
Nikesh Yadav
niya is on a distinguished road
I am getting error while converting gmsh(.msh) mesh to foam.
fileName::stripInvalid() called for invalid fileName /home/niyaa/testedcases/mshToFm
For debug level smile emoticon 2) > 1 this is considered fatal
Aborted (core dumped)
I am attaching my .msh file in with ,txt extension. just change the extension to .msh .
I was trying this tutorial on gmsh to foam.
https://www.youtube.com/watch?v=OymPRfSjtYY
this is my system problem for sure ..the same mesh converted successfully on my university cluster. and my friend computer. i am using openfoam30 installed using ubuntu deb pack on my ubuntu 14.04.
niya is offline   Reply With Quote
Old   March 12, 2016, 12:01
Artur's Avatar
Artur
Artur will become famous soon enough
This error is usually caused by things like spaces or invalid characters in one of the paths, presumably the path to the case, which would explain why things worked on other machines. Make sure the case doesn't have any strange characters in its name and things should work just fine.
A
Artur is offline   Reply With Quote
gmsh2tofoam, openfoam30
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
