[Other] Smoothness of derivatives at node points
Old   January 16, 2016, 23:32
Default Smoothness of derivatives at node points
Hilbert
Hillie is on a distinguished road
Dear Foamers
The mesh that I am working with involves a line segment, followed by an arc, and then an other line. I have positioned the points that link the lines with the arc segment in such a way that there should be smooth and continuous transition of the first and second derivative.
I get a first derivative that looks oke, but there is a distinct jump in the second derivative, which also shows up in the flow solution.
Does anybody know if there is a way that I can force the derivatives to be smooth on the link point?
Cheers
Hillie is offline   Reply With Quote
Old   March 12, 2016, 12:04
Artur's Avatar
Artur
Artur will become famous soon enough
I think it would help everyone if you posted some pictures of the problem you're describing? I take it you're using block mesh with arc and line edges, if yes then I'm afraid you cannot control the derivatives of these. You could try the spline edge, which potentially gives you a bit more flexibility.
A
Artur is offline   Reply With Quote
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 15:18
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
License server not visible from master node Charles FLUENT 0 October 30, 2007 18:48
