[mesh manipulation] How I can Renumber the Elements on my mesh? |
December 15, 2015, 23:02 |
Luis Felipe Rojas
Rep Power: 11 |
Good Nigth , My name is Luis Rojas . I have a Hexahedral Mesh , this has 36727 elements . I want to do an análisis of this mesh with the double of this. Can you help me to know how to change the number of elements of my mesh?
Thanks See the photo of the mesh here. https://drive.google.com/file/d/0B1P...ew?usp=sharing |
December 19, 2015, 15:15 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick questions:
December 25, 2015, 22:54 |
Alberto Passalacqua
Rep Power: 36 |
To refine the mesh, you could try refineMesh too, if re-meshing is too complicated.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
December 26, 2015, 20:44 |
Thanks
Luis Felipe Rojas
Rep Power: 11 |
The version I am using is windows 10 Version 15.06 thanks , The real question of this forum is ... if i have a Hexaedral mesh with n volumens and edges.. etc.. how I can change that number of faces and volumens changing the 1D and 2D hypothesis.
December 26, 2015, 22:11 |
Alberto Passalacqua
Rep Power: 36 |
I am not sure what the Windows version has to do with this.
To run a 2D case, you need 1 cell in the third direction only, while for 1D cases. you need 1 cell only, in the second and third direction.
refine mesh, renumbering elements mesh |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
2D Mesh of Line Elements - Possible? | adjpayot | SU2 | 1 | February 24, 2018 12:58 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Gmsh] Physical Tag To Mesh Elements | FrancescoLRomeo | OpenFOAM Meshing & Mesh Conversion | 0 | June 3, 2016 12:43 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
