[snappyHexMesh] Refinement at wrong stage in SnappyHexMesh
Old   November 17, 2015, 14:12
Default Refinement at wrong stage in SnappyHexMesh
Jim Conger
james.conger is on a distinguished road
I'm doing something dumb in setting up a two phase problem, but I can't see it. The model uses a course 3D gradient mesh from blockMesh as a starting point, and then does four layers of refinement (refineMesh) in the area around the hull. For some reason the resultant shape from snappyHexMesh seems to follow a coarse outline of the model based on the initial grid rather than the refined grid.
Suggestions would be most welcome!
james.conger is offline   Reply With Quote
Old   November 18, 2015, 21:03
Default Answering my own question
Jim Conger
The odd messing was due to refinement being done in only two of the three axes. refineMeshDict must be set to explicitly refine each dimension, such as with this snippet:
coordinateSystem global;
globalCoeffs
tan1 ( 1 0 0 );
tan2 ( 0 1 0 );
tan3 ( 0 0 1 );
directions ( tan1 tan2 tan3 );
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 10:04
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[snappyHexMesh] Edge Refinement fracasce OpenFOAM Meshing & Mesh Conversion 3 December 2, 2017 14:30
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
