[snappyHexMesh] On which patches to set BC's for snappyHexMesh ?
Old   November 8, 2015, 19:25
Default On which patches to set BC's for snappyHexMesh ?
Tom Alderweireldt
Talder is on a distinguished road
three questions actually:
I'm trying to mesh an internal flow Venturi nozzle domain with snappyHexMesh. My STL file works fine (3 new patches created : inlet, outlet and walls).
1) Should I remove the BC's on the outside patches or leave them ? They have no purpose if you're modelling an internal flow.
(so only add boundary conditions for the new internal domain patches?)
2) The first results after castellated and snapped mesh look a bit strange to me. I was expecting a filled up 3D volume packed with many hex-cells, but when I look through the nozzle I see only very few cells, only around the walls, inlet and outlet patches. Did I miss something in order to obtain a fully meshed 3D volume ? (see image attached)
3) part of the surrounding background walls also got refined meshes, which I did not expect. Could this be related to a leaking mesh for my venturi nozzle, although I used the same circle for inlet/outlet patches as for the wall edges.
Best Regards,
Tom.
Talder is offline   Reply With Quote
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 17:35
How to set up BCs for k epsilon model Julian K. OpenFOAM Pre-Processing 44 October 26, 2015 10:23
How to set a initial temperature and constant heat flux at same BC's?? Jane FLUENT 4 October 25, 2015 13:01
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
problem of four patches set to cyclic boundary bryant_k OpenFOAM 9 September 22, 2013 13:42
