October 13, 2015, 18:52 |
Multilayer mesh in NetGen
Dear All,
I need to create a multilayer mesh in NetGen. I do that by creating each layer separately then merging them together. But when I use the mesh in a another software for simulations, it seems that only top layer is recognized by the software and other layers are not detected at all. Could anyone help me with this issue? Thanks very much. Vincent |
March 31, 2016, 00:10 |
Peter
Rep Power: 11 |
You can definitely do this with Netgen. You basically specify some boolean operations with polyhedra in the netgen (.geo) format. You can use the free Sketchup Meshkit Extension to do this with a GUI, or by hand with a text editor. A simple example file is attached (change the extension from *.txt to *.geo to try it out in netgen to see how it works! Kind regards, Peter |
mesh generation, netgen |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
[Netgen] Netgen mesh of a geometry with a cut fails | kontra | OpenFOAM Meshing & Mesh Conversion | 0 | November 28, 2013 10:46 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
