[mesh manipulation] cyclic BC for mesh from Pointwise
Old   October 7, 2015, 01:22
Default cyclic BC for mesh from Pointwise
soichiro
TypeR is on a distinguished road
Hi, I have a issue with exporting cyclic BCs from Pointwise.
The physics is simple, a upstream cylinder(diameter D) with downstream foil(chord length c, c=2D).
I built the mesh for DES simulation, with front and back side(perpendicular to spanwise direction, chord length apart, 40 cells in this direction) set to cyclic BC.
I've tried the approach:
1) set as cyclic in Pointwise, export to OF files, modify the boundary file by adding the line "neighbourPatch" for front and back
The checkMesh reported face not matching, and the face centers are definitely mismatched, it's might be a ordering issue
2) Set those two boundaries as patch in Pointwise and export. Use OF utility createPatch.
checkMesh reports non-orthogonal faces, convert to VTK and visualize in paraview(see attachment)
Please help! Thanks
TypeR is offline   Reply With Quote
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 09:03
LES in OF 3.0.1, no Output for nuSgs Mirage OpenFOAM Programming & Development 1 October 4, 2016 19:00
[Commercial meshers] Pointwise to Foam - cyclic BC points order Pj. OpenFOAM Meshing & Mesh Conversion 5 August 14, 2016 05:47
[Commercial meshers] Problem with cyclic BC's using Pointwise (non-orthogonality error!) Dan1788 OpenFOAM Meshing & Mesh Conversion 1 November 17, 2014 16:23
Possible createPatch/createBaffles bug? simpomann OpenFOAM Bugs 2 July 15, 2014 08:07
