[Other] Cylindrical annulus meshing
Old   September 6, 2015, 00:26
Default Cylindrical annulus meshing
iafpython's Avatar
Igor
iafpython is on a distinguished road
Hi Foamers,
Do you know if there is a tutorial for meshing a a cylindrical annulus ?
Is it better to do it with blockmesh, snappyhexmesh or c fields?
iafpython is offline   Reply With Quote
Old   September 17, 2015, 05:25
Nima Samkhaniani
nimasam is on a distinguished road
i feel its quite possible using blockMesh, look userguide how introduce arc and block using blockMesh.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   September 21, 2015, 04:55
cutter is on a distinguished road
Have a look at http://www.sourceflux.de/blog/lamina...ound-cylinder/.
They describe a pretty neat way to create the cylinder using a block mesh with a single block only. Depending on the symmetry properties of your problem this block needs to be replicated by mirroring along planes.
Cutter
cutter is offline   Reply With Quote
Old   September 21, 2015, 06:19
iafpython's Avatar
Igor
Thank you very much.
[ANSYS Meshing] Icem meshing queries Mfaizan ANSYS Meshing & Geometry 21 July 31, 2015 00:10
[GAMBIT] Meshing a spherical cavity over a cylindrical duct avd28 ANSYS Meshing & Geometry 1 July 17, 2015 03:05
[ICEM] cuboid and cylindrical surface quality meshing abhiaero ANSYS Meshing & Geometry 0 June 1, 2015 07:06
[Other] Problem with Cylindrical Pipe Meshing Shivam Sinha OpenFOAM Meshing & Mesh Conversion 1 November 7, 2014 04:21
Meshing a cylindrical volume pranab_jha ANSYS Meshing & Geometry 13 March 24, 2010 09:17
