[mesh manipulation] Is there a built in way to fix concave cells?
Old   August 18, 2015, 15:12
Default Is there a built in way to fix concave cells?
Richard Vega
richard_vega is on a distinguished road
I have been generating polyhedral meshes by using Salome/netgen to generate a tetrahedral mesh and then using polyDualMesh to convert to a polyhedral mesh. For the sake of this post, I will describe the simplest case of meshing a box this way. My problem is that the resulting polyhedral meshes seem to have quite a few concave cells. They are actually concave and appear on the corners of the cube (it is not simply complaining because there is a point on a flat surface and due to round off errors, it thinks it is concave. I have seen many posts saying this is common when using snappyhexmesh). Anyways, I am developing a method that will fail if there are any concave cells, so before I go writing my own code to fix concave cells, I wanted to check if anyone out there has any experience with fixing the concave cell problem, and if so, how they did it? Please assume I am complete beginner when it comes to OpenFOAM: i.e. never compiled a solver and am likely unaware of many utilities in existence. My experience is mainly in using the standard solvers and utilities.
richard_vega is offline   Reply With Quote
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 15:18
[ICEM] Problem with prism cells sidharath ANSYS Meshing & Geometry 0 September 1, 2015 08:09
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] snappyHexMesh Segmentation Fault avd28 OpenFOAM Meshing & Mesh Conversion 11 May 11, 2015 21:32
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 10:30
