[blockMesh] Setting up an airfoil cascade case in OpenFoam with block mesh
Old   August 6, 2015, 12:02
Default Setting up an airfoil cascade case in OpenFoam with block mesh
Jack
Jack001 is on a distinguished road
Hi all,
I have a geometry for 2D fan blade consisting of (x,y) points, and I wish to run a RANS simulation for the case when the blades are repeated in a 2D cascade. My blade has a rounded trailing edge and so I am thinking about using an O-grid. I wish to create my mesh using blockMesh. Does anyone have an example where they have done this or can help me out as to where I should start?
Many thanks in advance.
Jack001 is offline   Reply With Quote
Old   August 6, 2015, 12:32
hxaxtma is on a distinguished road
I have an octave script which reads the airfoil data and creates a blockMeshDict:
To start type in ysour terminal "octave meshgen_modified_octave.m"
You need geo_LS and geo_US.dat in the same folder as your script.
Maybe this is a good start for you
hxaxtma is offline   Reply With Quote
Old   August 6, 2015, 12:39
Jack
Great thanks! I actually had something similar for my meshing of an airfoil in a free stream, but I'm not sure how to proceed in order to make a cascade out of this! Thanks for your help.
block mesh, cascade, open foam
Setting up LES of Airfoil in OpenFoam Jack001 OpenFOAM 4 April 12, 2020 04:09
[Commercial meshers] openfoam: Interpolating available solution in a new case with a new mesh gggiulio OpenFOAM Meshing & Mesh Conversion 2 April 15, 2017 14:55
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
