[blockMesh] Multi-grading: Inconsistent point locations between blocks
Old   August 1, 2015, 13:21
Default Multi-grading: Inconsistent point locations between blocks
Mikko
Flowkersma is on a distinguished road
Hi everyone,
I have been testing the new multi-grading feature and found out some strange behaviour in it. BlockMesh fails sometimes if the multi-grading is specified on an edge which has opposite directions between the two blocks. I attached two examples: first one runs without problems but the second one gives an error "Inconsistent point locations between block pair 0 and 1." Only the amount of cells in k-direction is changed (i.e. 20,23 and 24 are OK and 21,22 are not). What is going on?
This one runs without problems:
vertices
    (-0.5 0.5 0.0)
    (0.5 -0.5 0.0)
    (0.5 0.5 0.0)
    (1.0 1.0 0.0)
    (1.0 -1.0 0.0)
    (-1.0 1.0 0.0)
    (-0.5 0.5 2.0)
    (0.5 0.5 2.0)
    (0.5 -0.5 2.0)
    (-1.0 1.0 2.0)
    (1.0 -1.0 2.0)
    (1.0 1.0 2.0)
    (-0.5 -0.5 0.0)
    (-0.5 -0.5 2.0)
blocks
    hex (5 3 11 9 0 2 7 6)  (40 40 20) edgeGrading (
1 1
 (0.3 0.4 4) (0.5 0.3 1) (0.2 0.3 0.25)
    hex (1 2 7 8 4 3 11 10)  (20 40 20) edgeGrading (
1 1
 (0.2 0.3 4) (0.50 0.3 1)  (0.30 0.4 0.25)
This one gives an error:
vertices
    (-0.5 0.5 0.0)
    (0.5 -0.5 0.0)
    (0.5 0.5 0.0)
    (1.0 1.0 0.0)
    (1.0 -1.0 0.0)
    (-1.0 1.0 0.0)
    (-0.5 0.5 2.0)
    (0.5 0.5 2.0)
    (0.5 -0.5 2.0)
    (-1.0 1.0 2.0)
    (1.0 -1.0 2.0)
    (1.0 1.0 2.0)
    (-0.5 -0.5 0.0)
    (-0.5 -0.5 2.0)
blocks
    hex (5 3 11 9 0 2 7 6)  (40 40 21) edgeGrading (
1 1
    hex (1 2 7 8 4 3 11 10)  (20 40 21) edgeGrading (
1 1
Flowkersma is offline   Reply With Quote
Old   August 1, 2015, 19:49
anonymous
ssss is on a distinguished road
I think that you should report this bug in the mantis openfoam tracker. They will surely take a look at it
ssss is offline   Reply With Quote
Old   August 2, 2015, 15:34
Mikko
Thanks, I did a bug report. http://www.openfoam.org/mantisbt/view.php?id=1809
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 06:11
[snappyHexMesh] Meshing multiple blocks Hanno OpenFOAM Meshing & Mesh Conversion 3 February 17, 2011 13:14
Floating point errors on a multi processor sim. Murat FLUENT 0 March 6, 2009 20:02
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
