[snappyHexMesh] refinementRegions in 3D
Old   July 29, 2015, 13:29
Default refinementRegions in 3D
Harak is on a distinguished road
Hey guys,
how can I create a refinement rectangle and/or box in three dimensions?
I know that you first have to define a shape, in this case a box, using searchableBox with:
    refinementBox
        type searchableBox;
        min (-1 -1 -1);
        max ( 5  1  1);
...and then set the refinement level in the refinementRegions with the region option mode inside.
    refinementRegions
        refinementBox
            mode inside;
            levels ((1e15 3));
But this is an example for a two dimensional case...how to do this in 3D?
Thanks in advance
Greetings
Harak
Harak is offline   Reply With Quote
Old   July 30, 2015, 08:33
Default is your mesh 3D ?
anonymous
iy-a is on a distinguished road
Hello
Did you check via paraFoam if your mesh (without refinements) is well 3D ?
In order to see this you can display "points" instead of "surface" and check if the values are inside your solid and not only on its surface.
if not, I guess that maybe get swiftSnap add-on for blender
and go to refinement regions and thick "refine inside" with
a sufficient value (for example 10m).
iy-a is offline   Reply With Quote
Old   July 30, 2015, 12:54
Originally Posted by iy-a View Post
Hello
Thanks for your replay.
Yes, of course my base mesh is 3D.
But in the meanwhile I figured it out on my own. The min and max values are actually the coordinates in the x, y and z plane. And because of this, it can be handled in 3 dimensions as well
mode inside, refinement regions, searchablebox
refinementRegions is undefined Gohu8 OpenFOAM Running, Solving & CFD 1 August 30, 2017 04:20
[snappyHexMesh] snappy not using all refinementRegions and refinementSurfaces suryansh OpenFOAM Meshing & Mesh Conversion 0 June 6, 2016 07:20
[snappyHexMesh] refinementRegions does not accept two directives per geometry part louisgag OpenFOAM Meshing & Mesh Conversion 0 June 30, 2015 05:50
[snappyHexMesh] refinementRegions ignored Jeanp OpenFOAM Meshing & Mesh Conversion 3 June 12, 2014 06:05
[Other] Rotation of refinementRegions in Snappy Ruli OpenFOAM Meshing & Mesh Conversion 0 December 13, 2013 19:16
