[snappyHexMesh] SnappyHexMesh and cell orientation region-wise |
July 20, 2015, 13:40 |
hekseli
Rep Power: 13 |
Hey!
I have been wondering if it is possible to force the cell orientation inside stl-surfaces different from the background blockmesh orientation? This in case I know that at some part of my domain I have flow not aligned with the background mesh. Naturally a smooth change back to background orientation is needed close to the interface and is totally expected. If this is not possible by some trick, then most probably I have to split the background blockmesh domain into pieces and orient the blocks correctly before applying snapping... |
July 22, 2015, 17:29 |
Regis
Rep Power: 14 |
I am facing the exact same problem. Hekseli, before someone enlighten us if this is possible, could you please explain in more details the workaround you mentioned?
July 23, 2015, 03:15 |
hekseli
Rep Power: 13 |
Hey!
I think the only way to overcome this is to design the background mesh in a way that the cells are orientated properly in it and then apply SHM. I am now creating the background structured mesh with gmsh. |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 10:26 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 18:16 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 05:17 |
[snappyHexMesh] snappyhexmesh cell splitted ununiform..2D case | sharonyue | OpenFOAM Meshing & Mesh Conversion | 1 | April 23, 2013 00:34 |
snappyHexMesh: cell lower corner instead of cell centre | andrea.pasquali | OpenFOAM Programming & Development | 4 | February 11, 2013 07:22 |
